It is currently Wed Aug 06, 2025 2:38 am
 Post subject: Torrified wood glue
PostPosted: Sun Jul 29, 2018 12:47 pm
First name: David
Last Name: Scheckman
City: Plainfield
State: VT
Zip/Postal Code: 05667
What’s the latest thinking on best glue and practices for torrefied red spruce and braces? Also wondering what thickness folks are using as a starting point for their torrefied tops? Seems like torrefied has been around long enough that there’s a bunch of experience with it out there.
David
 Post subject: Re: Torrified wood glue
PostPosted: Sun Jul 29, 2018 1:50 pm
I don't see why we'd glue it any differently. It's not like baking a piece of wood turns it into another species that's somehow resistant to gluing.
PostPosted: Sun Jul 29, 2018 2:10 pm
First name: David
City: Plainfield
State: VT
I’ve read various reports that torrefied wood is more demanding to glue since the cellular structure has been changed. Seems like many early adopters had glue failures.
PostPosted: Sun Jul 29, 2018 2:13 pm
Last Name: Beaver
City: Lake Forest
I was worried about that also. Torrified wood is supposed to act like old, seasoned wood. I do know that the pine and fir in 100 year old houses is quite hard, even to the point to where driving a nail into it can be difficult.
But, I have just finished three torrified sitka tops from StewMac with no problems. I just made sure I had freshly prepared joints and I glued with titebond as usual. Time will tell.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jul 29, 2018 3:12 pm
Either they don't know how to get good glue joints or they're just pissing on torrefaction because it's something they haven't used before. Alot of the time things like this are a self fulfilling prophecy.
Good woodworking practice eliminates alot of the supposed "issues" that folks seem to seek out on the internet.
PostPosted: Sun Jul 29, 2018 5:31 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Fish Glue.
Mike Collins
PostPosted: Sun Jul 29, 2018 6:00 pm
the only thing I do differently is to allow a bit more clamping time. Been using this for years and really like it.
PostPosted: Sun Jul 29, 2018 6:20 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
I use Old Brown Glue for both the center joint and to glue the braces on the torrefied tops I've done.
I don't even heat it up any more. I use it straight out of the bottle. I let it dry overnight and then it's good to go.
These users thanked the author DanSavage for the post: DanKirkland (Sun Jul 29, 2018 6:59 pm)
PostPosted: Mon Jul 30, 2018 10:18 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Torrefied wood does not absorb moisure as readily. This is the reason it is more stable. Since wood glues cure when the water in the glue is absorbed into the wood, it makes sense to allow more clamping time when gluing torrefied wood.
I have no experience with using torrefied wood, but I just got 100 red spruce tops back from the kiln. It is lighter and stiffer.
These users thanked the author John Arnold for the post: Pmaj7 (Tue Aug 07, 2018 11:50 pm)
PostPosted: Mon Jul 30, 2018 10:24 am
As mentioned, just clamp it longer. Titebond and hide glue both work well. 25+ torrefied top guitars without a problem...touch wood.
These users thanked the author meddlingfool for the post: Pmaj7 (Tue Aug 07, 2018 11:50 pm)
PostPosted: Mon Jul 30, 2018 11:23 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We baked our sole bottle of Titebond at 375 degrees (after filling the air space with a nitrogen/argon mix) for 96 hours...we now have torrified wood glue to use with our torrified brace and top wood.
Problem solved!
- Beth Brower
These users thanked the author Woodie G for the post (total 6): ernie (Wed Aug 08, 2018 7:22 am) • Pmaj7 (Tue Aug 07, 2018 11:51 pm) • Bri (Tue Aug 07, 2018 10:31 pm) • Steve Marcq (Fri Aug 03, 2018 2:27 pm) • DannyV (Thu Aug 02, 2018 11:14 am) • bftobin (Wed Aug 01, 2018 12:12 pm)
PostPosted: Mon Jul 30, 2018 12:29 pm
laughing6-hehe - Good one Woodie!
PostPosted: Wed Aug 01, 2018 5:14 pm
First name: Dan
Last Name: Savage
To clarify the concepts about torrefied wood and moisture, torrefied wood does not absorb *atmospheric* moisture as readily.
If you wipe a piece of torrefied wood with a damp rag, it will still get wet and the moisture will still soak into the wood, but it won't warp the wood.
PostPosted: Tue Aug 07, 2018 9:51 pm
First name: Oris
Last Name: Morton
City: Franklinton
My mentor taught me that Fish Glue was best for torrified tops... it’s what I use
PostPosted: Wed Aug 08, 2018 4:02 pm
"We baked our sole bottle of Titebond at 375 degrees (after filling the air space with a nitrogen/argon mix) for 96 hours...we now have torrified wood glue to use with our torrified brace and top wood.
Problem solved!"
That sounds half baked!....... you should have done it for 192 hours......
Users browsing this forum: No registered users and 44 guests
